I had a lot of troubles for making my 5Ghz channel visible to my Broadcom BCM4360 (including reinstallation of the drivers). Now, I can see all 5Ghz wifi networks that works ONLY on low channels (I guess <100). However, I cannot connect to 5Ghz wifi network - even though it started authentication, completed it and then - no connection. Moreover, connecting to 2,4 GHz network is painful as I got very low speed internet connection here - maximum is about 3-5 mbps on speedtests, sometimes it is not even 1 mbps. I tried following steps:
- Reinstalling drivers
- Installing wicd (it is slower than network-manager though after installation)
Blocking IPv6 (kind of, I used this):
sudo vim /etc/gai.conf
and uncommented:
precedence ::ffff:0:0/96 100
iwlist output:
wlp3s0 32 channels in total; available frequencies :
Channel 01 : 2.412 GHz
Channel 02 : 2.417 GHz
Channel 03 : 2.422 GHz
Channel 04 : 2.427 GHz
Channel 05 : 2.432 GHz
Channel 06 : 2.437 GHz
Channel 07 : 2.442 GHz
Channel 08 : 2.447 GHz
Channel 09 : 2.452 GHz
Channel 10 : 2.457 GHz
Channel 11 : 2.462 GHz
Channel 12 : 2.467 GHz
Channel 13 : 2.472 GHz
Channel 36 : 5.18 GHz
Channel 38 : 5.19 GHz
Channel 40 : 5.2 GHz
Channel 42 : 5.21 GHz
Channel 44 : 5.22 GHz
Channel 46 : 5.23 GHz
Channel 48 : 5.24 GHz
Channel 52 : 5.26 GHz
Channel 54 : 5.27 GHz
Channel 56 : 5.28 GHz
Channel 58 : 5.29 GHz
Channel 60 : 5.3 GHz
Channel 62 : 5.31 GHz
Channel 64 : 5.32 GHz
Channel 100 : 5.5 GHz
Channel 102 : 5.51 GHz
Channel 104 : 5.52 GHz
Channel 106 : 5.53 GHz
Channel 108 : 5.54 GHz
Current Frequency:2.422 GHz (Channel 3)
My ifconfig:
wlp3s0 IEEE 802.11 ESSID:"my_wifi_24"
Mode:Managed Frequency:2.422 GHz Access Point: 04:92:26:3A:93:F8
Bit Rate=5.5 Mb/s Tx-Power=200 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:on
Link Quality=47/70 Signal level=-63 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
Is there something I can do about it? I have also looked for dmesg, but the output shows my wlp3s0 card in IPv6:
[ 797.133189] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 797.290173] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 834.797229] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[ 837.013071] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
Please note that I also have built-in network card wlp2s0 that appears in dmesg like that:
[ 980.012074] wlp2s0: deauthenticating from 04:92:26:3a:93:f8 by local choice (Reason: 3=DEAUTH_LEAVING)
My arch is x64,kernel 4.15.0-47-generic and I am using Xubuntu
Description: Ubuntu 18.04.1 LTS
Release: 18.04
Update: I have installed the correct driver from the driver table provided in the other topic about broadcom
Update 2: Adding output of commands:
lspci -knn | grep -A4 -i "Network controller"
out:
03:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4360 802.11ac Wireless Network Adapter [14e4:43a0] (rev 03)
Subsystem: Broadcom Inc. and subsidiaries BCM4360 802.11ac Wireless Network Adapter [14e4:0619]
Kernel driver in use: wl
Kernel modules: bcma, wl
and:
sudo lshw -class network
out:
*-network
description: Wireless interface
product: BCM4360 802.11ac Wireless Network Adapter
vendor: Broadcom Inc. and subsidiaries
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: 03
serial: 50:3e:aa:d3:60:eb
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=wl0 driverversion=6.30.223.271 (r587334) ip=192.168.1.62 latency=0 multicast=yes wireless=IEEE 802.11
resources: irq:17 memory:f7400000-f7407fff memory:f7200000-f73fffff
