11
I have changed my DNS settings a few weeks back. It solved the problem and i forgot about it, but now I cant remember what changes I've done, because I've copied a few commands from askubuntu and it worked...
Now I want to flush my DNS but when I do as How can I flush the DNS on Ubuntu 17.04? I recieve this message:
sudo systemd-resolve --flush-caches
Failed to flush caches: Unit dbus-org.freedesktop.resolve1.service not found.
  1. What are the popular Ubuntu 18.04 networking providers?
  2. How do I flush my DNS and how to know its TTL or TTL of a record in it from command line?
Running: Ubuntu 18.04.2 LTS
sudo apt-get install whois
tgkprog
  • 585
  • 14
  • 30
The main network management daemon in Ubuntu is NetworkManager.
The error you're seeing might be caused by missing symlink inside /etc/systemd/system.
Please try to recreate it by using:
sudo ln -sf /lib/systemd/system/systemd-resolved.service /etc/systemd/system/dbus-org.freedesktop.resolve1.service
If you're having issues with systemd-resolved.service you can try to restart it. It should also flush DNS caches as a result.
sudo systemctl restart systemd-resolved.service
To see the domain TTL's you can use dig from dns-utils
apt install dnsutils
dig askubuntu.com
sample output:
;; ANSWER SECTION:
askubuntu.com.      247 IN  A   151.101.1.69
askubuntu.com.      247 IN  A   151.101.65.69
askubuntu.com.      247 IN  A   151.101.129.69
askubuntu.com.      247 IN  A   151.101.193.69
247 is the current TTL
Comar
  • 1,525
