When I try to install Telegram, I get the following error:
itsmarttricks@mangesh:~$ sudo apt-get install telegram
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libreoffice-core : Depends: libreoffice-common (> 1:6.2.2) but it is not going to be installed
libreoffice-java-common : Depends: libreoffice-common (= 1:6.2.2-0ubuntu0.18.04.1~lo1) but it is not going to be installed
libreoffice-report-builder : Depends: libreoffice-common (= 1:6.2.2-0ubuntu0.18.04.1~lo1) but it is not going to be installed
libreoffice-script-provider-bsh : Depends: libreoffice-common (= 1:6.2.2-0ubuntu0.18.04.1~lo1) but it is not going to be installed
libreoffice-script-provider-js : Depends: libreoffice-common (= 1:6.2.2-0ubuntu0.18.04.1~lo1) but it is not going to be installed
libreoffice-script-provider-python : Depends: libreoffice-common (= 1:6.2.2-0ubuntu0.18.04.1~lo1) but it is not going to be installed
libreoffice-style-colibre : Depends: libreoffice-common (= 1:6.2.2-0ubuntu0.18.04.1~lo1) but it is not going to be installed
libreoffice-style-elementary : Depends: libreoffice-common (= 1:6.2.2-0ubuntu0.18.04.1~lo1) but it is not going to be installed
libreoffice-style-tango : Depends: libreoffice-common (= 1:6.2.2-0ubuntu0.18.04.1~lo1) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
