I recently got an old computer to install Ubuntu 18.04.2 LTS on. I did and it worked at first, but it kept freezing and crashing.
I don't remember doing anything different, but it doesn't seem to freeze and crash anymore, but it's unusable because the screen resolution is so low.
My only option is 640x480. This is way too low. Nothing fits on the screen. In order to browse the web, I have to zoom out by 50% and it's just unbearable. I've tried every possible way to increase the screen resolution, but nothing works. The monitor supports up to 1680x1050.
The computer runs Windows 7 on a separate disk and Windows 7 works fine. For some reason, Ubuntu no longer works. I can not figure out why this is happening or how to fix it. I have tried xrandr and everything.
lspci -v output:
00:00.0 RAM memory: NVIDIA Corporation MCP61 Memory Controller (rev a1)
Subsystem: Hewlett-Packard Company MCP61 Memory Controller
Flags: bus master, 66MHz, fast devsel, latency 0, NUMA node 0
Capabilities:
00:01.0 ISA bridge: NVIDIA Corporation MCP61 LPC Bridge (rev a2)
Subsystem: Hewlett-Packard Company MCP61 LPC Bridge
I/O ports at 4f00 [size=256]
00:01.1 SMBus: NVIDIA Corporation MCP61 SMBus (rev a2)
Subsystem: Hewlett-Packard Company MCP61 SMBus
Flags: 66MHz, fast devsel, IRQ 11, NUMA node 0
I/O ports at 4900 [size=64]
I/O ports at 4d00 [size=64]
I/O ports at 4e00 [size=64]
Capabilities:
Kernel driver in use: nForce2_smbus
Kernel modules: i2c_nforce2
00:01.2 RAM memory: NVIDIA Corporation MCP61 Memory Controller (rev a2)
Flags: 66MHz, fast devsel, NUMA node 0
00:02.0 USB controller: NVIDIA Corporation MCP61 USB 1.1 Controller (rev a3) (prog-if 10 [OHCI])
Subsystem: Hewlett-Packard Company MCP61 USB 1.1 Controller
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 23, NUMA node 0
Memory at fbfff000 (32-bit, non-prefetchable) [size=4K]
Capabilities:
Kernel driver in use: ohci-pci
00:02.1 USB controller: NVIDIA Corporation MCP61 USB 2.0 Controller (rev a3) (prog-if 20 [EHCI])
Subsystem: Hewlett-Packard Company MCP61 USB 2.0 Controller
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 22, NUMA node 0
Memory at fbffec00 (32-bit, non-prefetchable) [size=256]
Capabilities:
Kernel driver in use: ehci-pci
00:04.0 PCI bridge: NVIDIA Corporation MCP61 PCI bridge (rev a1) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
Capabilities:
00:05.0 Audio device: NVIDIA Corporation MCP61 High Definition Audio (rev a2)
Subsystem: Hewlett-Packard Company MCP61 High Definition Audio
Memory at fbff8000 (32-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:07.0 Bridge: NVIDIA Corporation MCP61 Ethernet (rev a2)
Subsystem: Hewlett-Packard Company MCP61 Ethernet
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 24, NUMA node 0
Memory at fbffd000 (32-bit, non-prefetchable) [size=4K]
I/O ports at e480 [size=8]
Capabilities:
Kernel driver in use: forcedeth
Kernel modules: forcedeth
00:08.0 IDE interface: NVIDIA Corporation MCP61 SATA Controller (rev a2) (prog-if 85 [PCI native mode-only controller, supports bus mastering])
Subsystem: Hewlett-Packard Company MCP61 SATA Controller
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 21, NUMA node 0
I/O ports at e400 [size=8]
I/O ports at e080 [size=4]
I/O ports at e000 [size=8]
I/O ports at dc00 [size=4]
I/O ports at d880 [size=16]
Memory at fbffc000 (32-bit, non-prefetchable) [size=4K]
Capabilities:
Kernel driver in use: sata_nv
Kernel modules: sata_nv, pata_acpi
00:08.1 IDE interface: NVIDIA Corporation MCP61 SATA Controller (rev a2) (prog-if 85 [PCI native mode-only controller, supports bus mastering])
I/O ports at d800 [size=8]
I/O ports at d480 [size=4]
I/O ports at d400 [size=8]
I/O ports at d080 [size=4]
I/O ports at d000 [size=16]
Memory at fbff3000 (32-bit, non-prefetchable) [size=4K]
Capabilities:
00:09.0 PCI bridge: NVIDIA Corporation MCP61 PCI Express bridge (rev a2) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, NUMA node 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Capabilities:
Kernel driver in use: pcieport
00:0b.0 PCI bridge: NVIDIA Corporation MCP61 PCI Express bridge (rev a2) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Capabilities:
00:0c.0 PCI bridge: NVIDIA Corporation MCP61 PCI Express bridge (rev a2) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Capabilities:
00:0d.0 VGA compatible controller: NVIDIA Corporation C61 [GeForce 6150SE nForce 430] (rev a2) (prog-if 00 [VGA controller])
Subsystem: Hewlett-Packard Company C61 [GeForce 6150SE nForce 430]
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 10, NUMA node 0
Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f9000000 (64-bit, non-prefetchable) [size=16M]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities:
Kernel modules: nvidiafb, nouveau
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor HyperTransport Configuration
Flags: fast devsel, NUMA node 0
Capabilities:
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Address Map
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Miscellaneous Control
Capabilities:
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 10h Processor Link Control
