I'm running Ubuntu 18.04 on my laptop. I am trying to ping other computers on my local network using their hostname but it's not working.
$ ping ubuntudesktop
ping: ubuntudesktop: Name or service not known
I have the name servers for the wifi adapter set up as follows: Wifi adapter DNS settings
I am snooping the wifi packets using wireshark and I do not see any DNS query when I run the ping command. Why are these nameservers not being used?
On a side note - when I use nslookup for google.com for example I get the following:
$ nslookup google.com
Server:     127.0.0.53
Address:    127.0.0.53#53
Non-authoritative answer:
Address: 172.217.14.238
Address: 2607:f8b0:400a:803::200e
I am assuming Server is the address of the DNS server? Isn't 127.0.0.53 an address for the loopback interface? Would this mean it's essentially querying itself?
127.0.0.53 is the address used by systemd-resolved.service
tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      1224/systemd-resolv
udp        0      0 127.0.0.53:53           0.0.0.0:*                           1224/systemd-resolv
Hostnames of other computers will not be resolved trough the DNS service.
You need to specify them in /etc/hosts statically.
Example:
127.0.0.1 localhost
127.0.1.1 mypc
192.168.1.100 ubuntudesktop
You can edit this file trough sudo
sudo editor /etc/hosts
Comar
  • 1,525
