[Unit]
Description=captive portal automation
[Service]
Type=simple
ExecStart=/usr/bin/python /home/pi/do.py
Restart=on-failure
RestartSec=5
The above is the content of a systemd service called caportal.service running on an Ubuntu 14.04 machine. I need to repeat the service for every 30 minutes. How can i do that ?
/home/pi/do.py
import requests,json
import netifaces as ni
import commands as cm
gateway=ni.gateways()['default'][ni.AF_INET][0]
IPaddr=ni.ifaddresses('wlan0')[ni.AF_INET][0]['addr']
mac=ni.ifaddresses('wlan0')[ni.AF_LINK][0]['addr'].upper().replace(':','-')
ssid=cm.getoutput('iwgetid -r')
Home="http://"+gateway+":8010/"
URL=Home+"login.html"
print URL
d={}
d['IdSession']=mac
d['Language']='English'
d['refrescar']='0'
d['ip']=IPaddr
d['mac']=mac
d['DSP']=Home
d['AC']='1'
d['userlog']='vishnu'
d['userpass']='12345'
d['read']='checkbox'
d['Login']='+++Go+++'
try:
    if ssid=='machCochin':
        r=requests.post(URL,data=d)
        print r.status_code
        #raise ValueError("ERROR simulated")
    else:
        print "network is not machCochin"
except Exception as e:
    pass
terdon
  • 104,119
mcv
  • 53
systemd provides an ananalog of the cron jobs. They are called timer.
You need to create both a .service file to run your script and a .timer file with matching filename to schedule it.
Something like:
[Unit]
Description=run my script
[Timer]
OnCalendar=*-*-* *:00/5:05
Persistent=true
[Install]
WantedBy=timers.target
To run every 5 minutes for example. I let you dig the man page or you search engine to look the OnCalendar directive or others too.
You can even run as a user by placing both files in ~/.config/systemd/user/ or as root in /etc/systemd/system
You need activate the timer to get it running after you reboot
sudo systemctl enable myservice.timer
Add --user to the command above (and without sudo) if you run as a user from ./config
Then, run it with
sudo systemctl start myservice.timer
or
systemctl --user start myservice.timer
solsTiCe
  • 9,515
@martin-w to answer your question, you could add OnBoot directive under the Timer section. Something like
[Unit]
[Timer] OnCalendar=--* *:00/5:05 OnBootSec=5 Persistent=true
[Install] WantedBy=timers.target
You can check this link for more info.
