The Set Up
  • Phone - Moto z3 - developer mode ON, debugging mode ON
  • easytether - v 1.1.19
  • Ubuntu - 18.04.2
Actions taken
  1. installed easytether Pro
  2. installed drivers (easytether_0.8.9_amd64.deb) dpkg -i easytether_0.8.9_amd64.deb
  3. ran following cmd sudo easytether-usb returns error message
interface tun-easytether is used by another process (hotplug?)
What I've Tried
  1. Restarting both phone and laptop.
  2. Turned wi-fi on and off
  3. Restarted the network manager sudo systemctl restart network-manager.service
  4. Restarted the ModemManager sudo systemctl restart ModemManager-manager.service
  5. Even though it states it's for 16.04 I added source-directory interfaces.d to my etc/network/interfaces file.
  6. As per easytether pro documentation tried running the following commands
# systemctl enable systemd-networkd
# systemctl start systemd-networkd
systemd-networkd not found?
The questions
  1. Is it an issue that the interface tun-easytether is being used? If it is how can I find out whats engaging it?
  2. If the process lock isn't my issue, where should I logically looking?
Went over the easytether-pro documentation again and under Ubuntu 18.04 it instructs user to enable/start systemd-networkd
sudo systemctl restart systemd-networkd.service
This time I used the command-line completion on the string "systemd" and one of the results were systemd-networkd.service
Having the '.service' at the end seems new to 18.06.
Anywho I'm on the lines which is what matters. Hope this helps others.
David Parks
  • 2,586
