A few days ago I updated Python from version 3.6.7 to 3.7.1 based on the instruction found here on an Ubuntu 18.04. Since then, a No Entry Sign appeared on the top of the Desktop and the GUI Software & Update and Terminal shortcut Ctrl+Alt+T stopped working.
I tried several solutions including sudo apt update and sudo apt upgrade but none worked. More precisely, when I run sudo apt update I receive the below result.
Traceback (most recent call last):
  File "/usr/lib/cnf-update-db", line 8, in <module>
    from CommandNotFound.db.creator import DbCreator
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 11, in <module>
    import apt_pkg
ModuleNotFoundError: No module named 'apt_pkg'
Error in sys.excepthook:
  File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 63, in apport_excepthook
    from apport.fileutils import likely_packaged, get_recent_crashes
  File "/usr/lib/python3/dist-packages/apport/__init__.py", line 5, in <module>
    from apport.report import Report
  File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in <module>
    import apport.fileutils
  File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in <module>
    from apport.packaging_impl import impl as packaging
  File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 24, in <module>
    import apt
  File "/usr/lib/python3/dist-packages/apt/__init__.py", line 23, in <module>
    import apt_pkg
Original exception was:
    import apt_pkg
Reading package lists... Done
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
I wonder if anyone can help to repair the problem or downgrade to previous version of Python. I appreciate your help in advance.
