I have three command applets on a panel. They are displaying correctly but the journal is showing this assertion fail every time an applet refreshes.
This happens on only one of my 19.04 machines. I have 3
command-applet[31803]: gtk_label_set_text: assertion 'GTK_IS_LABEL (label)' failed
Even though they display correctly, the panel often becomes unresponsive so that application links stop working.
Something is wrong, but I don't know where to look next.
@DKBose
The command applet is essentially a dynamic panel label. It sits on a desktop panel and displays the output of an associated script. For example I display the IP, the external IP, VPN status. Simple scripts. When the script logic fails the command applet will display whatever error message the script has generated.
The applet is very simple. I doubt there is any involvement of 3D but that is a guess. If I discover otherwise, I'll post.
The applet is MATE standard issue,the github repo is here :
https://github.com/mate-desktop/mate-applets.git
@N0rbert
Desktop compositor : Marco (Adaptive)
Log file : syslog
To reproduce:
- rclick panel, choose 'Add to Panel'
- In the 'Add to Panel' dialog, choose 'Command / Shows the output of a command'
- Panel will add a label showing the current time. This is the default command.)
- rclick the new label, choose 'Preferences'
- In the 'Command' field, enter the full path to the script
- In the 'Interval' field, set the number of seconds to put between refreshes
- Close the dialog
Here is a script that puts the current workspace name:
#!/bin/bash
echo $(wmctrl -d | awk '/\*/ {print $10}')
Here are the relevant dconf entries as given by dconf dump / :
[org/mate/panel/objects/object-19]
locked=true
applet-iid='CommandAppletFactory::CommandApplet'
position=768
toplevel-id='top'
object-type='applet'
panel-right-stick=false
[org/mate/panel/objects/object-19/prefs]
command='/home/stephen/bin/workspace.cur'
And after N0rbert's comment on another panel-related issue from some time ago -- Question recently upvoted by some remarkable coincidence :
apt-cache policy mate-panel python-mate-menu libmate-menu2
mate-panel:
Installed: 1.20.5-1
Candidate: 1.20.5-1
Version table:
*** 1.20.5-1 500
500 http://ca.archive.ubuntu.com/ubuntu disco/universe amd64 Packages
100 /var/lib/dpkg/status
python-mate-menu:
Installed: 1.20.2-1
Candidate: 1.20.2-1
Version table:
*** 1.20.2-1 500
libmate-menu2:
Installed: 1.20.2-1
Candidate: 1.20.2-1
Version table:
*** 1.20.2-1 500
