I need to install Java jdk 11 on my lubuntu laptop, but when I write this in the terminal: sudo apt-get install oracle-java11-installer I get this:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
google-chrome-stable : Depends: libappindicator3-1 but it is not going to be installed
oracle-java11-installer : Depends: java-common (>= 0.24) but it is not going to be installed
Recommends: gsfonts-x11 but it is not going to be installed
Recommends: oracle-java11-set-default but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
and
openjdk-11-jre-headless : Depends: ca-certificates-java but it is not going to be installed
Depends: java-common (>= 0.28) but it is not going to be installed
for sudo apt install openjdk-11-jre-headless
How do I fix this?
when i tried fix broken install I got this
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
I don't really care if I get open or oracle java, I just need to install jdk.
I have Lubuntu 18.10
when using sudo apt install I get this error:
Thanks
