$ sudo apt-get install oracle-java8-installer
Reading package lists... Done
Building dependency tree
Package oracle-java8-installer is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'oracle-java8-installer' has no installation candidate
Asked
Active
Viewed 2,363 times
Soren A
- 7,191
I still use java version 8 and follow these steps to install via command line whenever I nuke an OS
add the discontinued repository, it will automatically install the repository for the newer version but will not prevent you from installing previous versions of java
sudo add-apt-repository ppa:webupd8team/java && sudo apt-get update
install java version 8 default, jre or jdk
sudo apt-get install oracle-java8-set-default
# or
sudo apt install openjdk-8-jdk
# or
sudo apt install openjdk-8-jre
verify your version of java
java -version
set your environment variables
export JAVA_HOME=/usr/lib/jvm/java-8-oracle
export JRE_HOME=/usr/lib/jvm/java-8-oracle/jre
Oracle recently changed the licensing for their JDK/JRE to require everybody to have a subscription to get newer releases than 8u201. You can either switch to another JDK or buy the subscription and download/install the new oracle-jdk package manually.
Most software should run fine with openjdk-8-* - this might therefore be a worthwhile first test.
