I've successfully used mkusb to install a persistent Ubuntu 18.04.2 LTS system on a new Samsung T5 USB SSD. What is nice about mksusb is that it creates a bootable system that works on a wide variety of computer systems. However, I would like to have a portable 'real' Ubuntu installation vs. a live/persistent install that works with both UEFI and BIOS boot methods.
The process outlined here looked like it would do the trick, but in my case I'm just presented with the grub prompt when booting the drive. Note, that I interpreted the step:
Cut grub.cfg from sdx5/boot/grub and paste to sdx3/boot/grub, overwriting the existing grub.cfg file
...to mean that I should move the new grub.cfg file from /dev/sdx5/boot/grub to /dev/sdx3/boot/grub, overwriting the grub.cfg file created by mkusb and deleting the grub configuration file created by the installation from the installation partition. Also, /dev/sdx3 was not mounted after the Ubuntu installation completed, I had to manually mount it (/dev/sdx5 was already mounted on /target).
Since mkusb without modifications works fine with the T5 SSD drive, I assume that there is something about the Ubuntu 18.04.2 LTS installation grub.cfg file that is causing an issue.
Is there an alternative approach that would work, or is there something inherently different with a portable SSD vs. a USB thumb drive that prevents creating a truly portable drive?
Update: I just ran through the process linked above with a spare 64GB micro-USB drive, and it worked fine. I was able to boot it via BIOS and UEFI modes. I think I can safely rule out the specific version of Ubuntu (18.04.2) as the source of the problem, and assume that there is something unique about using a USB SSD vs. a 'standard' thumb drive... not sure if it's the drive size or the hardware interface (I suspect the latter).
Slab
  • 41
I've finally determined that the mkusb process linked to in my original question can indeed be used to create a 'real' Ubuntu install, on a portable USB SSD or thumb drive, that boots on both BIOS and UEFI systems.
As it turns out, my assumption as to this step in that process:
...was simply incorrect. One doesn't actually 'cut' the grub.cfg file from the /dev/sdx5 partition, you need to 'copy' the grub.cfg file to the /dev/sdx3 partition. As mentioned, /dev/sdx3 was not mounted after the Ubuntu installation, and /dev/sdx5 was mounted on /target. I manually mounted /dev/sdx3 on /media/ubuntu (that directory is created by the installation process it seems) and then copied the file over the mkusb iteration:
sudo mount /dev/sdx3 /media/ubuntu
sudo cp /target/boot/grub/grub.cfg /media/ubuntu/boot/grub
That simple adjustment is all that was necessary, otherwise the procedure that @C.S.Cameron detailed works perfectly well with a portable SSD!
Slab
  • 41
