I know that it has been asked before (for example here), but I am completely stuck and have no idea how to make it work.
I am trying to setup several ftp users, each with its own subfolder (so the user can see only he his root folder, and nothing else).
current issue is that on filezilla I am getting
Command:    open "user1@123.123.123.123" 22
Command:    Trust new Hostkey: Once
Command:    Pass: ******
Error:  Authentication failed.
Error:  Critical error: Could not connect to server
/etc/vsftpd.conf
listen=YES
listen_ipv6=YES
anonymous_enable=NO
local_enable=YES
write_enable=YES
local_umask=022
dirmessage_enable=YES
use_localtime=YES
xferlog_enable=YES
xferlog_file=/var/log/vsftpd.log
connect_from_port_20=YES
nopriv_user=vsftpd
virtual_use_local_privs=YES
guest_enable=YES
user_sub_token=$USER
local_root=/home/ftpmain/ftp/$USER
hide_ids=YES
guest_username=vsftpd
secure_chroot_dir=/var/run/vsftpd/empty
ssl_enable=YES
allow_anon_ssl=NO
ssl_tlsv1=YES
ssl_sslv2=NO
ssl_sslv3=NO
require_ssl_reuse=NO
ssl_ciphers=HIGH
pasv_address=123.123.123.123
pasv_enable=Yes
pasv_min_port=40000
pasv_max_port=50000
chroot_local_user=YES
chroot_list_enable=NO
/etc/pam.d/vsftpd
auth required pam_pwdfile.so pwdfile /etc/vsftpd/ftpd.passwd
account required pam_permit.so
the user1 folder looks like this (after chmod+chown):
/home/ftpmain/ftp/user1$ ll
total 12
dr-xr-xr-x 3 root   root    4096 Mar 18 19:17 ./
dr-xr-xr-x 4 nobody nogroup 4096 Mar 18 19:09 ../
drwxr-xr-x 2 vsftpd nogroup 4096 Mar 18 19:17 folder1/
netstat
$ netstat -tlpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      -
tcp6       0      0 :::22                   :::*                    LISTEN      -
Any idea about what I am missing and how to make it work? Is there any way to debug it? some log files that I can check why login fails?
Any help would be appreciated, let me know if you need further info
P.S: running on ubuntu 18.04
UPDATE
I found this error in the /var/log/auth file:
$ tail -f /var/log/*
Apr 30 15:05:49 ip-172-31-40-232 sshd[25641]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=111.111.111.111
Apr 30 15:05:51 ip-172-31-40-232 sshd[25641]: Failed password for invalid user user1 from 111.111.111.111 port 53251 ssh2
Apr 30 15:05:51 ip-172-31-40-232 sshd[25641]: error: Received disconnect from 111.111.111.111 port 53251:13: Unable to authenticate [preauth]
Apr 30 15:05:51 ip-172-31-40-232 sshd[25641]: Disconnected from invalid user user1 111.111.111.111 port 53251 [preauth]
I discovered that vsftpd isn't running at all! The reason that I didn't see it before, is because I had SFTP working (using port 22). the vsftpd status was 'Failed'.
$ sudo /etc/init.d/vsftpd status
● vsftpd.service - vsftpd FTP server
   Loaded: loaded (/lib/systemd/system/vsftpd.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Tue 2019-04-30 15:45:56 UTC; 2s ago
  Process: 25980 ExecStart=/usr/sbin/vsftpd /etc/vsftpd.conf (code=exited, status=2)
  Process: 25972 ExecStartPre=/bin/mkdir -p /var/run/vsftpd/empty (code=exited, status=0/SUCCESS)
 Main PID: 25980 (code=exited, status=2)
I run the vsftpd manually from command line and discovered there is a certificate error
$ sudo /usr/sbin/vsftpd /etc/vsftpd.conf
500 OOPS: SSL: cannot load RSA certificate
justadev
  • 273
I fixed this issue by adding the certificate to the conf file
rsa_cert_file=/etc/ssl/private/vsftpd.pem
rsa_private_key_file=/etc/ssl/private/vsftpd.pem
justadev
  • 273
