This printer does not print colour when I attach it to my laptop running Ubuntu 18.04. Using recommended driver for Samsung C48x series PS.
It works correctly when I print via Windows 7 on the same laptop.
Can anybody tell me what to make it work, printing colour also on Ubuntu?
Open Firefox and type:
http://127.0.0.1:631/
In order to access CUPS and check your default printing settings.
CUPS is the standards-based, open source printing system developed by Apple Inc. for macOS® and other UNIX®-like operating systems.
Ced
  • 853
  • 13
  • 33
Assuming you have correctly installed your printer on Ubuntu 18.04 check out this thread open your chosen browser (Firefox, Chromium etc) and in the address bar type http://localhost:631/
This will open up the CUPS utility allowing you to select your printer and modify its defaults.
Select your printer then go to Administration >Set Default Options.
Under Color Mode use the drop down menu to select Color
Alternatively, go to Settings > Devices > Printers and select Additional Printer Settings... at the bottom of the screen right click on the printer and select Properties. Then move down to Job Options and select print-color-mode and select to color. Then click on Apply then OK
graham
  • 13,061
