17
The system does not start. Did it by using rm - R accidentally. How can I recover the system?
αғsнιη
  • 36,350
Mouvre
  • 317
You need to reinstall all applications which have files in /usr/share.
  1. Boot system from Recovery Mode with root prompt.
  2. Remount rootfs to read-write mode with mount -o rw,remount /.
  3. Raise up ethernet interface and get IP address from DHCP server: dhclient enp0s3 (check correct interface name in ip a or ifconfig -a).
  4. Specify DNS server by
    rm /etc/resolv.conf
    echo "nameserver 192.168.1.1" > /etc/resolv.conf
    (change 192.168.1.1 to yours gateway/router)
  5. You need to fix the dpkg package as it misses the /usr/share/dpkg/cputable file (otherwise you will face the "E: error reading the cpu table" on any apt/apt-get command)
    wget http://mirrors.kernel.org/ubuntu/pool/main/d/dpkg/dpkg_1.19.0.5ubuntu2.1_amd64.deb
    dpkg -i dpkg_1.19.0.5ubuntu2.1_amd64.deb
    or installing it from cache:
    dpkg -i /var/cache/apt/archives/dpkg_*.deb
  6. update package cache:
    apt-get update
  7. reinstall essential componenets
    apt-get install --reinstall debconf linux-base
    mkdir /usr/share/python
    apt-get install --reinstall python2.7-minimal python3-minimal
  8. and then use one-liner below:
    apt-get install --reinstall $(dpkg -S /usr/share/ | sed 's/,//g' | sed 's/: \/usr\/share//g')
    Above:
    • dpkg -S /usr/share/ shows the list of comma-separated packages
    • sed 's/,//g' - removes commas
    • sed 's/: \/usr\/share//g' - removes : /usr/share in the end
    This part may fail with messages about some packages. For example on my VM I have had a problem with bsdmainutils, so I reinstalled them with:
    dpkg -i /var/cache/apt/archives/bsdmainutils_*.deb
    and then reran one-liner above.
  9. fix broken packages
    dpkg --configure -a
    apt-get install -f
  10. finally fix /etc/resolv.conf link by
    rm /etc/resolv.conf
    ln -s /run/systemd/resolve/stub-resolv.conf /etc/resolv.conf
  11. reboot.
Note: the resulting fixed system do not show any problems while running sudo apt-get check or sudo debsums --all --changed.
N0rbert
  • 103,263
Short answer: you can't and you have to reinstall the apps, as suggested by a previous answer.
However, before that, I would mount the drive in another computer and test undelete utilities which are available for ext3/ext4. A quick search in Google points to these ones:
extundelete: http://extundelete.sourceforge.net/
easeus: https://www.easeus.com/resource/drive/ext3.htm
TestDisk: https://www.cgsecurity.org/wiki/TestDisk
How to guide: http://translatedby.com/you/howto-recover-deleted-files-on-an-ext3-file-system/original/
etc.
