I am trying to listen to an Android phone device and display it in console (basically establish connection and verify that it works).
I am not sure if this is the issue with Ubuntu drivers. Can I request anyone to let me know any possible solutions or even the direction I should be looking for? Any help will be gratefully acknowledged.
Edit As per @vidarlo 's valuable comments, I am adding the following details: I am trying to run my custom Joypad app that I had built along the lines of github.com/TraQuad/TraQuad-Controller three years ago. It was working beautifully with Windows. I wish to use that android joypad (similar to Arduino BT Joystick free) and run my simulator in Ubuntu. I am not sure if Sony has disabled that profile via system updates. sdptool browse gave the following result: https://pastebin.com/s90jZWis
Edit 3
I am able to see /dev/rfcomm0 now after following Bluetooth on Ubuntu 16.04 (maybe, it is also due to some of the other posts I tried). However, when I try Unable to create dev/rfcomm port , I get
sudo picocom -c /dev/rfcomm0 picocom v2.2
port is : /dev/rfcomm0 flowcontrol : none baudrate is : 9600 parity is : none databits are : 8 stopbits are : 1 escape is : C-a local echo is : yes noinit is : no noreset is : no nolock is : no send_cmd is : sz -vv receive_cmd is : rz -vv -E imap is : omap is : emap is : crcrlf,delbs,
Type [C-a] [C-h] to see available commands
Terminal ready
FATAL: term closed
Edit 4 It is highly likely that I have used insecure connection as Xperia Dual M2 device is quite old. I was going through Android documentation https://developer.android.com/reference/android/bluetooth/BluetoothDevice.html#createInsecureRfcommSocketToServiceRecord(java.util.UUID) and the reference code https://github.com/TraQuad/TraQuad-Controller/blob/master/app/src/main/java/com/example/prasadnr/traquad/ProJoypad.java#L759 I have used 00001101-0000-1000-8000-00805F9B34FB . So, the question reduces to How can I listen to insecure bluetooth serial connection in Ubuntu?
Edit 5 I am trying https://askubuntu.com/a/104954/950668 and https://stackoverflow.com/a/13041129/10978972 But, I am not able to get it working even now.
Edit 6
I tried to run sudo rfcomm connect rfcomm0 A0:E4:53:D8:91:80 and I got
Can't connect RFCOMM socket: Connection refused . So, I was going through this https://stackoverflow.com/a/52221644/10978972 . But, I did not find Service Name: Serial Port after running the command. So, is this the problem with Ubuntu or with the Android phone?
