I run Ubuntu 18.04 on a modern Toshiba laptop without problems - until updating on Apr 26 2019. It needed restart. After that Gnome opened windows terribly slowly. I removed all Gnome extensions, ran sudo apt update, sudo apt autoremove, sudo apt full-upgrade, but no difference. Is this a virus? Help!? I am a near-80 astrophysicist but an Ubuntu dud and appreciate help...
Addition Apr 29: other posts made me look at dmesg. At its end:
[211509.868273] [drm:intel_pipe_update_end [i915]] ERROR Atomic update failure on pipe A (start=458201 end=458202) time 207 us, min 1073, max 1079, scanline start 1069, end 1083
[212774.344829] perf: interrupt took too long (22682 > 22655), lowering kernel.perf_event_max_sample_rate to 8750
Are these meaningful?
Addition May 6 2019: getting desperate. Top shows that the machine runs fine. Booting with my original installer 18.04 USB stick does not have the problem. I tried the previous kernel: same problem. I tried login with Gnome from Xorg: same problem. May be not a Gnome problem because other things are very slow too, Ethernet by a factor 5-10. I presume one of the many packages I installed does this after the update? - but how find it?
