I use forward X windows connections a lot (using "ssh -X ...").
How can I see which window is from which user and machine?
Ideally I'd like each non-local window title bar to display "fred@server3.example.com" or similar.
Sorry, I hadn't made the question clear.
I'm not just asking about remote terminal windows, I'm asking about all X forwarded windows, such as Firefox, Thunderbird, etc.
fadedbee
  • 828
  • 16
Your ~/.bashrc can tell if it's a ssh connection by looking at environment variables:
walt@bat:~(0)$ env | grep SSH
SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
walt@bat:~(0)$ ssh $USER@localhost
walt@localhost's password:
Welcome to Ubuntu 16.04.6 LTS (GNU/Linux 4.15.0-48-generic x86_64)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/advantage
0 packages can be updated.
0 updates are security updates.
Last login: Sun Apr 21 11:09:24 2019
SSH_CLIENT=127.0.0.1 49228 22
SSH_TTY=/dev/pts/5
SSH_CONNECTION=127.0.0.1 49228 127.0.0.1 22
walt@bat:~(0)$ logout
Connection to localhost closed.
walt@bat:~(0)$
Then, you can use xttitle to set the window title (sudo apt install xttitle).
Something like
if [[ -n "$SSH_CONNECTION" ]] && [[ -n "$DISPLAY" ]] ; then
    xttitle "SSH Connection $USER@$(hostname)"
fi
waltinator
  • 37,856
