I know this question has been asked before, but I cannot find a solution for Ubuntu 18.04
I have an external hard drive (FAT32) that had a default name with spaces that was making my life hell for scripting. So I manually changed the mount point to /media/$user/Ext1TB but now I do not have write access to the disk and cannot save or modify the content. It used to work fine.
Things I have tried:
sudo chown -R $USER:$USER path/to/folder
gksu nautilus (doesn't work on 18.04?)
sudo chmod -R 777 /<folder name or path>
changing permissions through sudo nautilus (works but does not stay like that)
So I am a bit out of ideas. Any other suggestion that doesn't involve formatting?
I have already looked at the following posts:
Edit:
Thanks to guiverc I now understand the problem with FAT32 permissions. I have tried the following with no result:
sudo mount /dev/sda1 /media/$USER/Ext1TB
should I add the -w? The help says it is implicit. Can somebody help with the mount call?
From what I understand of the post suggested to make it permanent I have to add or modify a line in fstab similar to this:
UUID=8C52-C1CD /home/storage auto user,umask=000,utf8,auto 0 0
But I have no idea on how to build the line, find the correct UUID number and set the correct options. Any suggestion with that?
