If I login and manually run mount -a it mounts without any problems. But auto-mount is not running.
I've tried the following:
`//192.168.0.85/someshare/Directory /var/log/remoteMount cifs auto,credentials=/home/admin/.smbcredentials,vers=3.0,iocharset=utf8,noperm 0 0`
//192.168.0.85/someshare/Directory /var/log/remoteMount cifs credentials=/home/admin/.smbcredentials,vers=3.0,iocharset=utf8,noperm,_netdev 0 0
`//192.168.0.85/someshare/Directory /var/log/remoteMount cifs credentials=/home/admin/.smbcredentials,vers=3.0,iocharset=utf8,noperm,_netdev,x-systemd.automount 0 0`
`//192.168.0.85/someshare/Directory /var/log/remoteMount cifs credentials=/home/admin/.smbcredentials,vers=3.0,iocharset=utf8,noperm,x-systemd.automount 0 0`
Each time on boot i get the following error in dmesg CIFS VFS: cifs_mount failed w/return code = -2
In all the above attempts, auto-mount does not work (each time tested by rebooting and checking for directory contents). However each time i ran mount -a everything works.
How can i get auto-mount working in /etc/fstab when using ver=3.0 and when using .smbcredentials instead of storing username and password in /etc/fstab?
UPDATE:
Also tried:
//192.168.0.85/someshare/Directory /var/log/remoteMount cifs credentials=/home/admin/.smbcredentials,vers=3.0,iocharset=utf8,noperm,noauto,x-systemd.automount 0 0
which won't automount or mount with mount -a
Using @reboot sleep 10; mount -a in root crontab with the first thing i tried in /etc/fstab for now.
