I tried to install the libopencv-nonfree-dev package in Ubuntu 16.04 using the command:
sudo add-apt-repository --yes ppa:xqms/opencv-nonfree
sudo apt-get update
sudo apt-get install libopencv-nonfree-dev
But I got the error below:
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
libopencv-nonfree-dev : Depends: libopencv-features2d-dev (= 2.4.9.1+dfsg-1.5ubuntu1xqms2~xenial1) but 2.4.9.1+dfsg-1.5ubuntu1.1 is to be installed
Depends: libopencv-nonfree2.4v5 (= 2.4.9.1+dfsg-1.5ubuntu1xqms2~xenial1) but it is not going to be installed
What could I do to install it then?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Khai
I had some success with this alternative PPA. For completeness, I removed the other one first. I also had to reinstall the main OpenCV package.
sudo add-apt-repository --remove ppa:xqms/opencv-nonfree
sudo add-apt-repository --yes ppa:jeff250/opencv
sudo apt-get update
sudo apt-get install libopencv-dev
entheh
  • 121
