Since upgrading from Kubuntu 18.10 to 19.04, baloo_file_extractor is constantly gobbling up between 30-80% of my cpu and up to 50% of my 8gb ram, making my system slow and unstable.
Running balooctl disable does not seem to stop it, and if I try to kill its process it simply respawns.
In the short term, is there any way to disable it so I can get on with work.
And more generally, should I report this as a bug (have never reported to launchpad before so that I'd check here).
Thanks!
kokoro
  • 31
Beyond disabling baloo, the solution to fixing baloo on my machine was to increase the inotify folder watch limit, as described on the Arch wiki.
sudo nano /etc/sysctl.d/40-max-user-watches.conf
Add the line:
fs.inotify.max_user_watches=524288
Save, then re-enable baloo (assuming it had already been disabled):
sudo balooctl enable; sudo balooctl start
I came across this solution by looking through journalctl --since "1 day ago" and repeatedly finding the line KDE Baloo File Indexer has reached the inotify folder watch limit. File changes will be ignored. A web search of that pointed the way to the solution. Baloo now runs quietly in the background.
Hope that helps anyone else who experiences the same issue.
kokoro
  • 31
