When installing davfs2 on Ubuntu bionic, I have got the following errors:
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: davfs2 : Depends: libneon27 but it is not going to be installed
Then I have to install previous version of libneon27 first to make it right.
sudo apt install libneon27=0.30.2-2build1
I assume this is indeed a known issue confirmed bug 1826063
For know I am trying to configure using an older release of neon27:
sudo apt-mark hold libneon27
sudo apt -y install davfs2
Kapako
  • 51
