I've installed everything go-related from synaptic and later added ppa as described in the wiki: https://wiki.ubuntu.com/Go yet I cannot do "go get" for example
go get code.google.com/p/gorilla/mux
says that go command is not found.
How should I install this "go" command?
Jorge Castro
  • 73,717
That's a tool that seems to be released recently. If you install the golang-weekly package instead of golang-stable (available also through the ppa:gophers/go PPA), you'll see that go is available under /usr/bin directory.
jcollado
  • 9,868
It works if you follow this procedure: Installing the Go Language
You have to modify your ~/.bashrc as follows.
nano ~/.bashrc
export GOPATH=/srv/go
if [ -d "/usr/lib/go/bin" ] ; then
    PATH="${GOPATH}/bin:/usr/lib/go/bin:${PATH}"
fi
Rolf
  • 625
