I am on Kubuntu 18.10 with python 2.7.15 and 3.6.7 installed and output of lsb_release -a is
LSB Version: core-9.20170808ubuntu1-noarch:security-9.20170808ubuntu1-noarch
Distributor ID: Ubuntu
Description: Ubuntu 18.10
Release: 18.10
Codename: cosmic
pip works on my machine since its for python 2.7 and output of pip -V is
pip 9.0.1 from /usr/lib/python2.7/dist-packages (python 2.7)
But typing pip3 gives segfault. The output is just Segmentation fault. Same output for pipenv. I have tried removing and installing python3-pip several times, deleted pip cache in /home/<username>/.cache. When i try to add any PPA using apt-add, i get this output
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 380, in get_ppa_info
ret = get_ppa_info_from_lp(user, ppa)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 110, in get_ppa_info_from_lp
return get_info_from_lp(lp_url)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 104, in get_info_from_lp
return get_info_from_https(lp_url, True)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 96, in get_info_from_https
data = func(lp_url=url, accept_json=accept_json, retry_delays=retry_delays)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 139, in _get_https_content_py3
cafile=LAUNCHPAD_PPA_CERT)
File "/usr/lib/python3.6/urllib/request.py", line 210, in urlopen
raise ValueError('SSL support not available')
ValueError: SSL support not available
During handling of the above exception, another exception occurred:
Traceback (most recent call last):
File "/usr/bin/add-apt-repository", line 136, in <module>
shortcut = shortcut_handler(line)
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 1020, in shortcut_handler
ret = factory(shortcut)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 469, in shortcut_handler
return PPAShortcutHandler(shortcut)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 426, in __init__
info = get_ppa_info(self.shortcut)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 392, in get_ppa_info
_get_suggested_ppa_message(user, ppa))
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 349, in _get_suggested_ppa_message
lp_user = get_info_from_lp(LAUNCHPAD_USER_API % user)
Another symptom why i think there is an issue with ssl is that when i import ssl in python2 terminal, it works. But importing ssl in python 3.6 gives segfault
Python 3.6.7 (default, Oct 22 2018, 11:32:17)
[GCC 8.2.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import ssl
Segmentation fault (core dumped)
UPDATE
When i import any other module before ssl, say hashlib, i get a different error
>>> import hashlib
>>> import ssl
File "<stdin>", line 1, in <module>
File "/usr/lib/python3.6/ssl.py", line 101, in <module>
import _ssl # if we can't import it, let the error propagate
ImportError: /usr/local/lib/libssl.so.1.1: version `OPENSSL_1_1_1' not found (required by /usr/lib/python3.6/lib-dynload/_ssl.cpython-36m-x86_64-linux-gnu.so)
