The kernel on booting initrd, shows the error 'Initramfs unpacking failed: junk in compressed archive', with a message of kernel panic. Is this an issue with cpio, as I'm using Ubuntu 16.04 or some internal error caused by the /init daemon script?
I have met similar problems when I am trying to install 4.19-longterm in ubuntu21.10.
The reason is that 4.x kernels don't support zstd compressing algorithm, but with which cpio compresses initramfs.
To solve it, edit /etc/initramfs-tools/update-initramfs.conf and replace the compressing algorithm to gzip or others supported by your kernel.
run update-grub to refresh the rootfs in /boot/ and reboot.
- 11
I had a very similar error on 20.04 on a Thinkpad X220. (Core i5, 8GB RAM, dual-booting with Win10; Ubuntu and Win10 are on separate SSDs.)
20.04 worked for a while and then started failing to boot with errors about being unable to unpack the initrd and disk errors on the console.
I found if I went back to an older kernel (via GRUB's Advanced Options menu) it would boot.
It was scary: I thought my SSD was dying, so I bought a new one.
I copied my partitions onto a new disk with Gparted off a live USB and
put it in a different machine. I booted off a USB key, checked my
partitions for errors with fsck -f, and managed to boot into
recovery mode (VERY slowly) and then installed the newer HWE kernel.
This fixed it. It booted fine, without errors except a missing
resume device (I used ZRAM and had no swap partition, in order to avoid undue SSD wear).
I have read that newer SSDs are much more robust so I created a swap
partition, put a line for it into /etc/fstab. The errors continued.
I had to rebuild my initrd which I've never had to do before, but
this fixed it.
So, emboldened, I tried to fix the old laptop. I fsck-ed the
partitions, I ran trim on them, I installed the HWE kernel, I
created a swap partition on the other (Windows) SSD and purged ZRAM
and rebuilt my initrd.
The machine is still running just fine and now I have a spare SSD I don't really need, which is a bit annoying. But it only cost me as much as a takeaway meal, so that is not too bad.
- 741
