I am trying to access the GRUB from my ubuntu installation as shown here: How to get to the GRUB menu at boot-time?
But I get the following result. How can I get to the GRUB? Any Idea? SCREENSHOT
Adding the output of cat /etc/default/grub
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="nomodeset"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
giulio
  • 171
This screenshot shows the boot device selection menu from bios. Once you select the first option, grub is loaded. Press ESC quick and you should be able to access grub.
Note: The screenshot you attached is bios menu for choosing boot device. Select the first option (Ubuntu) then press Shift or Esc to access grub menu.
Here is what I did to make changes permanent. Edit the file /etc/default/grub
sudo nano /etc/default/grub
Then replace
GRUB_TIMEOUT_STYLE=hidden
with
GRUB_TIMEOUT_STYLE=menu
EDIT: If the above line does not exist then add it.
And make sure GRUB_TIMEOUT is not set to 0.
Then run sudo update-grub and then restart you should see grub menu everytime you power on your notebook. To undo the changes replace the file with original contents and run sudo update-grub
knoftrix
  • 419
