EDIT: This is now not working at all, and I still don't have a solution for it. Symptoms are as below: I can access the printer from ALL non-Ubuntu devices on the same LAN, but not from my Ubuntu 16.04 box. Any ideas? Thanks.
I'm trying to troubleshoot a connection from an ThinkPad E460 running Ubuntu 16.04 to a networked HP LaserJet Pro M402dw printer:
- Laptop and printer connected to network via wifi.
- Frequently goes from working to broken and back again within a few minutes, without my deliberately changing any settings.
- Connection from laptop to Internet works fine.
- Connection from other devices on LAN to printer work fine.
When it's working, I can ping the printer at its 192.168.1.xxx IP address from my laptop at 192.168.1.yyy. On Wireshark, the ping looks like this:
Time Source Destination Protocol Length Info
[time] 192.168.1.yyy 192.168.1.xxx ICMP 98 Echo (ping) request...
[time] 192.168.1.xxx 192.168.1.yyy ICMP 98 Echo (ping) reply...
When it's not working, I can't ping the printer and arp -a reports its MAC address as "incomplete." On Wireshark, it's clear that the ping itself is never actually transmitted. Instead my laptop, at "IntelCor_[MAC]," sends an unanswered ARP request as follows:
[time] IntelCor_[MAC] Broadcast ARP 42 Who has 192.168.1.xxx? Tell 192.168.1.yyy
Following the suggestion here, I tried using a script in /etc/network/if-up.d/ to set a static ARP entry for the printer, as follows:
#!/bin/sh
arp -i wlp1s0 -s 192.168.1.xxx [MAC address] # HP printer
It still works sometimes, but not always. The connection can drop after the network is up, and restarting the network doesn't necessarily fix it. With this static ARP entry in place, the failed ping request looks like this:
[time] 192.168.1.yyy 192.168.1.xxx ICMP 98 Echo (ping) request...(no response found!)
Note that this seems superficially similar to the networking problem described here, but I think I’ve already eliminated the possible software causes described in that thread. The only thing I haven't done is change out the physical network hardware.
Any suggestions on possible causes or how to troubleshoot further?
Additional information:
When it's not working:
- I can’t access the printer’s web interface from my laptop.
- When I try to print, Ubuntu printer properties window reports “Filter failed."
- snmp, dnssd, lpinfo, and avahi-browse show no information about the printer.
- I can still access the printer reliably from my iPhone and a Windows computer via the same wifi network.
Additional notes:
- Printer sleep mode is off for testing.
- Laptop’s iptables firewall is off for testing.
- Printer’s firewall is off.
- Printer’s access control list is set to allow all connections in the local network (192.168.xxx.0, subnetmask 255.255.255.0).
- The wifi network is a Unifi system with two wireless access points running under one network name. The DHCP server is on, and there are no duplicate IP addresses on the network.
Previously requested output:
$ nmcli device
DEVICE TYPE STATE CONNECTION
wlp1s0 wifi connected [Network Name]
enp0s31f6 ethernet unavailable --
lo loopback unmanaged --
$ ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: enp0s31f6: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether [MAC address of laptop's ethernet card] brd ff:ff:ff:ff:ff:ff
3: wlp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether [MAC address of laptop's wifi card] brd ff:ff:ff:ff:ff:ff
inet 192.168.1.99/24 brd 192.168.1.255 scope global dynamic wlp1s0
valid_lft 83676sec preferred_lft 83676sec
inet6 [IPv6 address]/64 scope link
$ sudo lshw -short -class network
H/W path Device Class Description
/0/100/1c/0 wlp1s0 network Dual Band Wireless-AC 3165 Plus Bluetoo
/0/100/1f.6 enp0s31f6 network Ethernet Connection I219-V
$ rfkill list
0: tpacpi_bluetooth_sw: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
4: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
$ ls -l /etc/resolv.conf
lrwxrwxrwx 1 root root 29 Jan 10 2017 /etc/resolv.conf -> ../run/resolvconf/resolv.conf
$ ls -l /run/resolvconf/resolv.conf
-rw-r--r-- 1 root root 196 Apr 17 10:56 /run/resolvconf/resolv.conf
Additional requested output:
$ nmcli device show wlp1s0 | grep IP4.DNS
IP4.DNS[1]: 192.168.1.1
IP4.DNS[2]: 1.1.1.1
IP4.DNS[3]: 1.0.0.1
$ cat /etc/resolv.conf
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 127.0.1.1
search [domain.tld]
Note that [domain.tld] is the nonresolvable domain name appended to all of the hostnames on the LAN. Also, FWIW, I always ping and access the web interface by IP address rather than hostname. Whenever I can't print, I can't even acess the printer by IP address from my laptop.
Additional requested information:
sudo grep -r -n "192.168.1.1" /run/resolvconf/* returns nothing.
There are only three files in /run/resolvconf:
/run/resolvconf/enable-updates: This is an empty file.
/run/resolvconf/resolv.conf: See above.
/run/resolvconf/interface/NetworkManager:
search [domain.tld]
