You need to connect via Ethernet cable to the network with DHCP server (dynamic IP addresses).
Then run DHCP client manually with sudo dhclient Tab (for auto-completion) and click Enter.
On my system the complete command is sudo dhclient enp0s3
Note: if unsure then run ip link and you will find at least two interfaces here:
$ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp0s3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
link/ether aa:bb:cc:dd:ee:01 brd ff:ff:ff:ff:ff:ff
and you will find ethernet as enp0s3 (may vary in your case). Ensure that you can ping some server on the net - for example ping ubuntu.com. If you cannot ping - then try with other (third) ethernet interface.
Then install manager to the system:
sudo apt-get install network-manager # for console
sudo apt-get install network-manager-gnome # for GNOME and Unity desktops
and then reboot.
