It's the same error as in several other posts, but none of the solutions work for me.
I'm typing
apt-get install ar<TAB><TAB>
and there's not auto-completion. I'm using an Ubuntu-Docker:
# Ubuntu Dockerfile
# https://github.com/dockerfile/ubuntu
# Pull base image.
FROM ubuntu:16.04
# Install.
RUN \
sed -i 's/# \(.*multiverse$\)/\1/g' /etc/apt/sources.list && \
apt-get update && \
apt-get -y upgrade && \
apt-get install -y build-essential && \
apt-get install -y software-properties-common && \
apt-get install -y byobu curl git htop man unzip vim wget openssh-server && \
rm -rf /var/lib/apt/lists/*
RUN add-apt-repository main
RUN add-apt-repository universe
RUN add-apt-repository restricted
RUN add-apt-repository multiverse
RUN apt-get update
#ArangoDB stuff
RUN curl -OL https://download.arangodb.com/arangodb34/DEBIAN/Release.key && apt-key add - < Release.key
RUN echo 'deb https://download.arangodb.com/arangodb34/DEBIAN/ /' | tee /etc/apt/sources.list.d/arangodb.list
RUN apt-get install apt-transport-https
RUN apt-get update
# Set environment variables.
ENV HOME /root
# Define working directory.
WORKDIR /root
# Define default command.
CMD ["bash"]
which is working.
At first I couldn't use any auto-complete at all. Enabling the sections in the .bashrc allowed me to get the install, but now I'm stuck. What I did so far:
sudo apt-get update
From apt-get autocomplete package name is broken
sudo apt-get install bash-completion
Enabled this in the /etc/bash.bashrc:
# enable bash completion in interactive shells
if ! shopt -oq posix; then
if [ -f /usr/share/bash-completion/bash_completion ]; then
. /usr/share/bash-completion/bash_completion
elif [ -f /etc/bash_completion ]; then
. /etc/bash_completion
fi
fi
In the .bashrc I enabled:
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
if [ -f /etc/bash_completion ] && ! shopt -oq posix; then
fi
Still, no changes. Is there something docker-specific I have to put into consideration?
Edit:
Apparently it's a shell-issue. I installed zsh. In zsh it's working as supposed.
I don't like to have this as a solution as I still don't understand why the regular shell refuses to work.
I have read about enabling auto completion for apt-get install in docker (ubuntu 14.04) - but frankly I don't quite get what the OP was doing to make it work.
