Cannot install Nvidia driver for RTX 2080 Ti in Ubuntu 18.04 LTS !!!!
I am trying to install nvidia driver with RTX 2080 Ti in Ubuntu 18.04 LTS
After Installing nvidia-driver (version 418.57) , the system will not boot . The following output comes and the screen stays blinking :
[code]/dev/sda4: recovering journal /dev/sda4: clean, some numbers / some numbers file, some numbers / some numbers blocks [/code]
Output after boot and the following screen blinks and get stuck
Please find the nvidia-bug report in following link https://b24-2wuuf9.bitrix24.com/~XxAYb
Output of following commands are :
lspci |grep -i nvidia
[code]65:00.0 VGA compatible controller: NVIDIA Corporation TU102 [GeForce RTX 2080 Ti Rev. A] (rev a1) 65:00.1 Audio device: NVIDIA Corporation TU102 High Definition Audio Controller (rev a1) 65:00.2 USB controller: NVIDIA Corporation TU102 USB 3.1 Controller (rev a1) 65:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU102 UCSI Controller (rev a1)[/code]
uname -m && cat /etc/*release
[code]x86_64 DISTRIB_ID=Ubuntu DISTRIB_RELEASE=18.04 DISTRIB_CODENAME=bionic DISTRIB_DESCRIPTION="Ubuntu 18.04.2 LTS" NAME="Ubuntu" VERSION="18.04.2 LTS (Bionic Beaver)" ID=ubuntu ID_LIKE=debian PRETTY_NAME="Ubuntu 18.04.2 LTS" VERSION_ID="18.04" HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" VERSION_CODENAME=bionic UBUNTU_CODENAME=bionic[/code]
gcc --version
[code]gcc (Ubuntu 7.3.0-27ubuntu1~18.04) 7.3.0 Copyright (C) 2017 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.[/code]
uname -r
[code]4.18.0-15-generic[/code]
I tried installing Nvidia driver through two different following methods :
Using PPA :
sudo add-apt-repository ppa:graphics-drivers/ppa sudo ubuntu-drivers autoinstall sudo apt install nvidia-418
Also through Nvidia site directly :
downloaded the display driver for Linux from https://www.nvidia.com/download/driverResults.aspx/138279/en-us
chmod +x NVIDIA-Linux-x86_64–410.57.run
sudo ./NVIDIA-Linux-x86_64–410.57.run --no-x-check
In both cases the result is same and the system would not boot and gets stuck at the error mentioned before .
