I am trying to use write a script that uses SSH to create a new directory and write to a text file in it. I've got 1 master on a network, and then 3 nodes that I want to create the directory on. These 4 machines are hosted on VMware.
#node1
ssh node1@192.168.1.102 'sudo touch /temp_dirname/host.txt'
ssh node1@192.168.1.102 'echo "node1" | sudo tee /temp_dirname/host.txt'
#node2
ssh node1@192.168.1.103 'sudo touch /temp_dirname/host.txt'
ssh node1@192.168.1.103 'echo "node1" | sudo tee /temp_dirname/host.txt'
#node3
ssh node3@192.168.1.104 'sudo touch /temp_dirname/host.txt'
ssh node3@192.168.1.104 'echo "node1" | sudo tee /temp_dirname/host.txt'
When I run this I get different errors for each node... for nodes 1 and 2 I get
touch: cannot touch '/temp_dirname/host.txt': no such file or directory
and
tee: temp_dirname/host.txt: no such file or directory
and node 3 I get:
touch: setting times of '/temp_dirname/ no such file or directory
and
I am absolutely confused with this as I thought touch created files - so why is it no such file or directory.
dessert
  • 40,956
Amy
  • 23
If /temp_dirname doesn't exist, you can create it with mkdir -p /temp_dirname.
-p works with any arbitrary depth, creating directories as required.
vintnes
  • 146
