Anyone who FOR SURE know how to install UBUNTU(ANY) on my brand new Lenovo idepad 330 with intel core i5, 7th gen? Please reply! I am going crazy over this! My 10 year old Acer could take 16.04 LTS without problems, but not 18.04 LTS. Please help!
No problem at all. I bought my ideapad 330 15IKB i5 8225U 2weeks ago, and I use W10 10 and ubuntu 18.04. not problem at all.
But just one thing to remind: your lenovo motherboard tend to choose windows instead of ubuntu. You should either select "legacy first" if you already have a hard disk of Ubuntu, or reinstall it to choose "install ubuntu alongside windows".
Last but not least, if your windows updates, or lenovo asks you to upgrade your bios, it probably will go back to windows boot which means, you have to manually change it back. But in general, not problem at all.
Kuai Yu
  • 834
Each model is different, but anyway, I am assuming that your new laptop is very similar to mine, that Win 10 is pre-installed and you want to install ubuntu alongside windows:
  1. From your OS (say your Win 10) go to ubuntu official website to download ubuntu 18.04 iso file, after the download, also download bootable usb creator, for instance Rufus.
  2. Prepare a 8GB clean USB and follow instruction for creating bootable USB for ubuntu installation.
  3. After that, without removing USB, reboot your PC and constantly press F2 to enter your BIOS, their, go to BIOS menu, select your USB as first bootloader (at your USB disk option you have to press F6 to move this option to the top), save and exit and should should be fine to enter Ubuntu installing menu.
  4. Once entered the ubuntu installation menu, select install ubuntu, and follow the instruction until you are asked to select what to do with your disk, I remember basically there are three options (1. Install Ubuntu alongside Windows; 2. Format disk and install Ubuntu and 3. Do something else).
5.1 If you don't know what to do and afraid to mess up with your computer and Win 10, just select the first one, and normally ubuntu will split your disk into two partitions, half for windows and half for ubuntu. Continue and install. All good.
5.2 If you want to have a smaller/bigger partition for Ubuntu/Win 10, then at step 4, you should select "try ubuntu without installing". Once entered the Ubuntu trial OS, use gparted to shrink your Win 10 partition to ideal capacity, apply and reboot (back to step 3)
5.2.1 Same as previously described at 5.1, this time choose do something else. And assign the unallocated partition as your root (/), whether assigning swap is completely up to you. And follow the instruction and you should be able to install ubuntu without any problem.
I attach a video of instruction, may it helps. https://www.youtube.com/watch?v=u5QyjHIYwTQ&t=218s
Remember to mark "problem solved (tick)" if your think this is helpful.
Kuai Yu
  • 834
