Problems with ubuntu apt-get install -f
W: Some index files failed to download. They have been ignored, or old ones used instead.
E: Problem executing scripts APT::Update::Post-Invoke-Success 'test -x /usr/bin/apt-show-versions || exit 0 ; apt-show-versions -i'
E: Sub-process returned an error code
E: Write error - write (28: No space left on device)
E: IO Error saving source cache
E: The package lists or status file could not be parsed or opened.
I tried mount back the tmp but it doesnts works Someone know How to fix it?
root@pipoca:/var/tmp# mount /tmp
mount: can't find /tmp in /etc/fstab
root@pipoca:/var/tmp# free -m
total used free shared buff/cache available
Mem: 3008 868 1327 13 812 1964
Swap: 263 0 263
root@pipoca:/tmp# df -h
Filesystem Size Used Avail Use% Mounted on
udev 1.5G 0 1.5G 0% /dev
tmpfs 301M 4.5M 297M 2% /run
/dev/vda1 25G 25G 0 100% /
tmpfs 1.5G 8.0K 1.5G 1% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 1.5G 0 1.5G 0% /sys/fs/cgroup
/dev/vda15 105M 3.6M 101M 4% /boot/efi
tmpfs 301M 0 301M 0% /run/user/0
root@pipoca:/# dpkg -l 'linux-*' | sed '/^ii/!d;/'"$(uname -r | sed "s/\(.*\)-\([^0-9]\+\)/\1/")"'/d;s/^[^ ]* [^ ]* \([^ ]*\).*/\1/;/[0-9]/!d' | xargs sudo apt-get -y purge
dpkg-query: no packages found matching linux-*
Reading package lists... Error!
using
sudo apt autoremove
sudo apt autoclean
I got
using
root@pipoca:/# sudo journalctl --vacuum-time=2d
Vacuuming done, freed 0B of archived journals on disk.
root@pipoca:/# journalctl --vacuum-size=500M
root@pipoca:/# apt-get update
Hit:1 http://mirrors.digitalocean.com/ubuntu xenial InRelease
Hit:2 http://mirrors.digitalocean.com/ubuntu xenial-updates InRelease
Hit:3 http://mirrors.digitalocean.com/ubuntu xenial-backports InRelease
Hit:4 http://software.virtualmin.com/vm/6/gpl/apt virtualmin-xenial InRelease
Hit:5 http://software.virtualmin.com/vm/6/gpl/apt virtualmin-universal InRelease
Hit:6 http://security.ubuntu.com/ubuntu xenial-security InRelease
Hit:7 https://packages.microsoft.com/ubuntu/16.04/prod xenial InRelease
Hit:8 http://archive.ubuntu.com/ubuntu xenial InRelease
not a reference at /usr/bin/apt-show-versions line 222.
Reading package lists... Done
