I have 2 flask restful API's .
On my localhost, I open up a terminal and run uwsgi --ini /path-to-ini-file1. For 2nd API, I open up yet agan a new terminal and run uwsgi --ini /path-to-ini-file2.
In VPS, I have only a single ssh window.
How do I run those 2 on terminals in vps using ssh. Should I create a bin/bash script to achieve that?
Any suggestion would be appreciated, thank you.
ksalf
To run commands in background and do not have them attach to the terminal you need to use something like:
nohup uwsgi --ini /path-to-ini-file1 >out1.log 2>err1.log&
nohup uwsgi --ini /path-to-ini-file2 >out2.log 2>err2.log&
And you can run as many as need servers (limited by RAM and processor power).
And after you logour from the server you will have them run
Romeo Ninov
  • 709
  • 13
If this is supposed to run on an unattended machine, make these a service, so that they are automatically taken care off (started,restarted, logged...). It is not difficult to make a systemd service.
xenoid
  • 5,759
