lets say that i have an apache server running, and two network cards.
each card is connected to a different network.
C1 is connected to N1, which is an ADSL connection with the port 80 open (so i can reach my server from oustide my lan).
C2 is connected to N2, which is a [very fast] corporate network (no ports open or routes allowed).
how could my server take advantage of C2N2 bandwidth?
would forcing download on one network and upload on another help?
EDIT 1:
what about bonding (seen here: Two ethernet ports on motherboard. How can I get double the bandwidth?)? would it help?
yodog
  • 296
Well... in a terminal with curl you can specify an interface.
From the manpage: curl --interface eth0:1 http://www.netscape.com/.
So for a single file you use something like this:
curl -LO --interface eth1 ftp://ftp.xs4all.nl/pub/test/10mb.bin
where eth1 is the interface connected to "C2N2".
Henk
  • 388
It's way more reading than you probably want to do, but you'll probably find this useful. Particularly the sections on source based policy routing (although you would be doing it based on source and/or destination) and split access. Also, if you did uploads/downloads on a particular port number, that would make it easy to match on.
RobotHumans
  • 30,112
