How can i downgrade the java version 11 to java 8. As i need jenkins, current jenkins versoin doesn't support java 11. I need to downgrade.
Asked
Active
Viewed 1.8e+01k times
107
You have to install the
openjdk-8-jre:sudo apt-get install openjdk-8-jreNext switch to the jre-8 version:
$ sudo update-alternatives --config java There are 2 choices for the alternative java (providing /usr/bin/java).Selection Path Priority Status
- 0 /usr/lib/jvm/java-9-openjdk-amd64/bin/java 1500 auto mode 1 /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java 1500 manual mode 2 /usr/lib/jvm/java-9-openjdk-amd64/bin/java 1500 manual mode
Add JAVA_HOME variable:
export JAVA_HOME=/usr/lib/jvm/java-8-openjdk-amd64check java version:
$ java -version openjdk version "1.8.0_151" OpenJDK Runtime Environment (build 1.8.0_151-8u151-b12-0ubuntu0.17.10.2-b12) OpenJDK 64-Bit Server VM (build 25.151-b12, mixed mode)
Same procedure for Oracle java.
