Retrieve info on the window state
You can get the info (and a lot more) from the command:
xprop -id <window_id>
To get what you are specifically looking for:
xprop -id 0x04c00010 | grep "_NET_WM_STATE(ATOM)"
The output will look like:
_NET_WM_STATE(ATOM) = _NET_WM_STATE_MAXIMIZED_HORZ, _NET_WM_STATE_MAXIMIZED_VERT, _NET_WM_STATE_HIDDEN
on a window that is maximized (h + v) and minimized at the same time, or just
(or no output at all) if none of those is the case.
More fun
Of course, using various languages, you can use Wnck, like in the python snippet below. (snippet from window-shuffler). The snippet outputs a list, showing the window name + either True or False (minimized).
#!/usr/bin/env python3
import gi
gi.require_version('Wnck', '3.0')
from gi.repository import Wnck
def get_winlist(scr=None, selecttype=None):
get the window list. possible args: screen, select_type, in case it is
already fetched elsewhere. select type is optional, to fetch only
specific window types.
if not scr:
scr = Wnck.Screen.get_default()
scr.force_update()
windows = scr.get_windows()
if selecttype:
windows = [w for w in windows if check_windowtype(w, selecttype)]
return windows
wlist = get_winlist()
for w in wlist:
print(w.get_name(), ",", w.is_maximized())
Output looks like:
Wnck.Window - Classes - Wnck 3.0 - Mozilla Firefox , True
Postvak IN - vlijm@planet.nl - Mozilla Thunderbird , True
Showtime , False
settingsexample.vala - Visual Studio Code , False
*Niet-opgeslagen document 1 - gedit , False
desktop_weather , False
Tilix: Standaard , False
N.B.
