20
I've install .NET Core on my Ubuntu 18.04 using sudo snap install dotnet-sdk --classic, but after the install process complete, the dotnet command still not working. Here is my console log:
long@long-ub1804:~$ sudo snap install dotnet-sdk
[sudo] password for long:
error: This revision of snap "dotnet-sdk" was published using classic
       confinement and thus may perform arbitrary system changes outside of the
       security sandbox that snaps are usually confined to, which may put your
       system at risk.
       If you understand and want to proceed repeat the command including
       --classic.
long@long-ub1804:~$ sudo snap install dotnet-sdk --classic
dotnet-sdk 2.2.202 from Microsoft .NET Core (dotnetcore✓) installed
long@long-ub1804:~$ dotnet --version
Command 'dotnet' not found, but can be installed with:
long@long-ub1804:~$ snap list
Name                  Version                    Rev   Tracking  Publisher    Notes
chromium              73.0.3683.86               669   stable    canonical✓   -
core                  16-2.38                    6673  stable    canonical✓   core
core18                18                         782   stable    canonical✓   base
docker                18.06.1-ce                 321   stable    canonical✓   -
dotnet-sdk            2.2.202                    32    stable    dotnetcore✓  classic
gnome-3-26-1604       3.26.0.20190228            82    stable/…  canonical✓   -
gnome-3-28-1804       3.28.0-9-gce87599.ce87599  23    stable    canonical✓   -
gnome-calculator      3.32.0+git2.cae338ea       352   stable/…  canonical✓   -
gnome-characters      v3.32.0+git1.9ff74a2       206   stable/…  canonical✓   -
gnome-logs            3.32.0                     57    stable/…  canonical✓   -
gnome-system-monitor  3.32.0                     70    stable/…  canonical✓   -
gtk-common-themes     0.1-16-g2287c87            1198  stable/…  canonical✓   -
pycharm-community     2019.1.1                   123   stable    jetbrains✓   classic
long@long-ub1804:~$
Luke
  • 605
You should try the following command
sudo snap alias dotnet-sdk.dotnet dotnet
Since snap doesn't provide automatic aliases for dotnet-sdk.
Regards,
Hayo Linn
  • 461
