Trying to share between 2 xubuntu machines on the same network:
sudo apt install samba from here, sudo apt install system-config-samba from here.
shares-admin from here didn't work initially - "Sharing services are not installed". Tried
sudo apt-get install nfs-kernel-server from here, now means I can open shares-admin, unlock it, try to add folders, and it crashes with
Segmentation fault
Opening Samba from the menu gives:
Failed to execute gksu system-config-samba. Failed to execute child process "gksu"
sudo apt install gksu
Package gksu is not available
Can't edit the shortcut in the menu because although the icon appears and is clickable, the entry isn't present in menu editor.
sudo system-config-samba
Traceback (most recent call last):
File "/usr/sbin/system-config-samba", line 45, in module
mainWindow.MainWindow(debug_flag)File "/usr/share/system-config-samba/mainWindow.py", line 121, in init
self.basic_preferences_win = basicPreferencesWin.BasicPreferencesWin(self, self.xml, self.samba_data, self.samba_backend, self.main_window)File "/usr/share/system-config-samba/basicPreferencesWin.py", line 97, in init
self.admin = libuser.admin()SystemError: could not open configuration file `/etc/libuser.conf': No such file or directory
sudo apt install thunar-shares-plugin
Unable to locate package
sudo /etc/init.d/samba restart
sudo: /etc/init.d/samba: command not found
This folder isn't present.
Does anyone have any tips for how to setup sharing on Xubuntu 18.10 & 18.04? This seems like it should be really simple and has immediately become nightmarish. Thanks.
