I've tried for hours to install nvidia drivers for my laptop. The standard nvidia-390, the newer nvidia-418 through the repo, various other versions, the .run files from Nvidia's website, tried changing into lightdm, tried the various grub parameters like nomodeset etc. Last thing I tried was installing nvidia-384 because why the hell not at this point, which resulted in a login loop. Not the first time this is happening either, the standard nvidia-390 does the same and I have no idea why. Has someone managed to install nvidia drivers in a similar system that could help me? Thank you. Edit: I've disabled secure boot, so unless my BIOS is lying to me, this shouldn't be an issue...
EDIT 2: After installing nvidia-driver-418 I can boot the system, but the command nvidia-settings give me this output:
ERROR: Unable to load info from any available system
(nvidia-settings:2477): GLib-GObject-CRITICAL **: 12:22:32.065: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 12:22:32.070: PRIME: No offloading required. Abort
** Message: 12:22:32.070: PRIME: is it supported? no
And the nvidia-settings window is empty. Any ideas?
I was faced with a similar problem while trying to install the Nvidia drivers for the RTX 2070.
May I suggest you look at how I solved the problem in this post, in case it helps.
The two important things to note are:
  • You need to install a driver which is compatible with your graphics card. You can check compatible drivers on the Nvidia website. From what I see there, the latest version 418 supports your graphics card (but please check yourself to make sure).
  • Make sure you use the command sudo apt-get install nvidia-driver-418 when installing your driver (not sudo apt-get install nvidia-418 which is obsolete).
Please let me know how if it worked.
johnwolf1987
  • 849
  • 18
