I want to run soapUI on Ubuntu 11.10. If I am not able to install via the package manager, I'd prefer not to install at all, and instead run as a standalone application. Looking at the soapUI download page I can't figure out which download (if any) fulfills this criterion?
  • soapui-4.5.0-Beta1-linux-bin.zip
  • soapUI-x32-4_5_0-Beta1.sh
I'm guessing "bin" but I don't know for sure. Any clues?
lofidevops
  • 21,912
Download the zip file. Then you just unzip the files into a directory somewhere. There is a sh file - you just need to make it executable and run that - from memory.
unzip soapui-*.zip
cd soapui-4.5.0-Beta1/bin/
chmod +x soapui.sh
./soapui.sh
trent
  • 2,384
Supposing that you don't have a GUI in your installation you can try from the command line simply using wget to download Linux tarball:
$ wget https://s3.amazonaws.com/downloads.eviware/soapuios/5.4.0/SoapUI-5.4.0-linux-bin.tar.gz
Then ungzip and untar the download archive:
$ gunzip SoapUI-5.4.0-linux-bin.tar.gz
$ tar xvf SoapUI-5.4.0-linux-bin.tar
Now instead of start the UI of SOAPUI using SOAPUI_HOME/bin/soapui.sh you can use SOAPUI/bin/testrunner.sh to run your projects without the UI.
albciff
  • 181
Unfortunately, there is no repository to be added to the sources, so SOAPUI cannot be installed through apt-get or Ubuntu package management. Some description is on https://www.soapui.org/getting-started/installing-soapui/installing-on-linux-or-unix.html . Resolution given by Trent is only option, but in reality, currently, you should download just .sh file (Linux installer) from https://www.soapui.org/downloads/latest-release.html which has approx. 130+MB and try following commands for 64bit:
$ sudo chmod +x SoapUI-x64-5.4.0.sh
$ ./SoapUI-x64-5.4.0.sh
or 32 bit:
$ sudo chmod +x SoapUI-x32-5.4.0.sh
$ ./SoapUI-x32-5.4.0.sh
(* scripts updated to version 5.4.0
Replace the name of the file according to the downloaded version of the SOAP UI. Enjoy your testing!
Dee
  • 1,986
On a 64 bit operating system, use the zip file installer. The shell installer includes a 32 bit jvm.
Eero Aaltonen
  • 1,424
  • 13
  • 33
