Just got into a new office, where there are two printers: 4505ac and 5005ac from Toshiba. There are no drivers available (in the database) for these models. Also I need to enter a department code somewhere?
On a previous version of Ubuntu, it is quite possible to setup a Toshiba e studio - https://www.youtube.com/watch?v=qh6nL4oVVHQ
On the official website with drivers - http://business.toshiba.com/support/downloads/index.html?model=5005ac it says there are Linux Filter Color drivers, which I honestly do not know how to install: Toshiba
In order to solve your problem, you need to follow these steps:
  1. Download a CUPS filter, any of these two options:
First download link is this one, and the second is this one.
  1. Decompress the tar files using the following command:
tar xvf TOSHIBA_ColorMFP_CUPS.tar --absolute-names
  1. Create queue (manually)
a. Enter the following command:
ls /opt/toshiba/tap/interface
b. If the above directory does not exist, enter the following command:
mkdir /opt/toshiba/tap/interface
c. Log on to the root account.
sudo su
d. Open your UNIX/Linux editor. e. Create the following file.
/opt/toshiba/tap/interface/<queue name>.conf
f. Add a line as below in the .conf.
dest=<IP address>
g. Save the file. h. Enter the following command: Color MFP:
cp /opt/toshiba/tap/model/net_estcolor /opt/toshiba/tap/interface/<queue name>
i. Enter the following command:
/opt/toshiba/tap/bin/modPrintcap -a <queue name> <IP address>
j. Enter the following command:
ls /opt/toshiba/tap/bin/flag_<queue name>
Then you should try to print.
More info: https://ubuntuforums.org/showthread.php?t=2139624
Official Installation Manual
Philippe Delteil's solution didn't work for for the CUPS filter. Instead I downloaded the linux.tar filter and followed some of his instructions:
$ sudo tar xvf linux.tar --absolute-names
$ sudo mkdir -p /opt/toshiba/tap/interface
Then I did steps 3c through 3i above in Philippe Delteil's instructions and printing worked.
