I'm using two boards, one running ubuntu desktop 18.04 and one running ubuntu server 18.04. In the desktop board, I have set a vlan by writing the /etc/network/interfaces file as described below (I know it is incorrect to set auto by first and than set a static address, but it is working anyhow and it is not the topic of my question):
auto eno1
iface eno1 inet dhcp
auto eno1.1
iface eno1.1 inet static
 address XX.XX.XX.91/23
 netmask 255.255.254.0
 gateway XX.XX.XX.1
 vlan-raw-device eno1
auto lo
iface lo inet loopback
I need to do just the same setting: two addresses on a unique physical port using vlan, naming like eno1 and eno1.1, with only eno1.1 defined as a static address, for the board where ubuntu server is loaded. I have seen the /etc/network/interface is not used at all and the networks must be set using /etc/netplan/50-cloud-init.yaml. I wasn't able to have a working board just following netplan.io/examples for vlan setting. So I would appreciate if you could help me showing how NN-cloud-init.yaml should look like to do just the same as in my /etc/network/interfaces file for the desktop.
Stormvirux
  • 4,536
CarloV
Try this skeleton. Some tweaking may be required. Fill out the appropriate MAC, IP's, and DNS. Keep the indentation, spacing, and no tabs.
network:
  version: 2
  renderer: networkd
  ethernets:
    mainif:
      match:
        macaddress: xx:xx:xx:xx:xx:xx
      set-name: mainif
      dhcp4: false
      dhcp6: false
      optional: true
  vlans:
    en01:
      link: mainif
      dhcp4: true
      dhcp6: false
    en01.1:
      link: mainif
      addresses: XX.XX.XX.91/23
      gateway4: XX.XX.XX.1
      nameservers:
        addresses: [8.8.8.8,8.8.4.4]
        search: [ domain1.example.com, domain2.example.com ]
sudo netplan --debug generate # generate config files
sudo netplan apply # apply configuration
reboot # verify proper operation
heynnema
  • 73,649
I have tried to rewrite your skeleton to provide the setting I needed. the 50-cloud-init.yaml file looks like below:
network:
version: 2
renderer: networkd
  ethernets:
    eno1:
      dhcp4: true
  vlan:
    eno1.1:
      link: eno1
      addresses: [XX.YY.ZZ.91/23]
that file generate devices just as I need, with an issue: the board remains isolated. From the board, I can ping localhost, eno1 and eno1.1, but not another board in the network and, by all means, another board in the network cannot ping that one. At that time I decided to use ifupdown as a shortcut for my problem, but maybe there is really nothing wrong in the 50-cloud-init.yaml. my speculation is that the packets are (most likely in a correct behavior) dropped because missing of a VLAN tag. In order to let the board to communicate to the externel world, I should probably change the 50-cloud-init.yaml as following:
network:
version: 2
renderer: networkd
  ethernets:
    eno1:
      dhcp4: true
  vlan:
    eno1.1:
      accept-ra: true
      link: eno1
I guess that would work. Unluckily, I cannot remove the installed ifupdown, so I cannot be sure 100% about my speculation.
One more info to complete the picture: even if you are using ifupdown, the standard 50-cloud-init.yaml must not be deleted. In fact, if you delete the standard 50-cloud-init.yaml, that looks like:
network:
  ethernets:
    eno1:
      dhcp4: true
version: 2
the dhcp4 would change the IP address assigned dynamically to the board.
One more time, let me thank you for your time and valuable support and again sorry for the late answer.
BR/Carlo
heynnema
  • 73,649
CarloV
