I installed Ubuntu for the first time half a year ago, so I'm a fairly new user.
Back then I installed Ubuntu 18.04 alongside Windows 10 with a dual boot setup, with Ubuntu being the default OS. A month ago I encountered a problem, which I could not find a solution to, so I had to reinstall Ubuntu from a bootable USB. Luckily, Ubuntu found that it was already installed and suggested to just overwrite the current installation of Ubuntu with a fresh one, which I of course selected.
Ubuntu works fine, but I don't have a lot of space, and I've had several warnings saying that The volume “filesystem root” has only XX MB disk space remaining. I have removed any unnecessary files to free up space, until I realized that my "main" drive is not mounted.
When I run df -h in a terminal, it outputs the following:
Filesystem Size Used Avail Use% Mounted on
udev 7.7G 0 7.7G 0% /dev
tmpfs 1.6G 2.1M 1.6G 1% /run
/dev/nvme0n1p5 19G 16G 2.1G 89% /
tmpfs 7.7G 12M 7.7G 1% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 7.7G 0 7.7G 0% /sys/fs/cgroup
/dev/loop0 92M 92M 0 100% /snap/core/6531
/dev/loop1 141M 141M 0 100% /snap/gnome-3-26-1604/74
/dev/loop2 91M 91M 0 100% /snap/core/6405
/dev/loop3 36M 36M 0 100% /snap/gtk-common-themes/1198
/dev/loop4 141M 141M 0 100% /snap/gnome-3-26-1604/82
/dev/loop5 90M 90M 0 100% /snap/core/6673
/dev/loop6 3.8M 3.8M 0 100% /snap/gnome-system-monitor/57
/dev/loop7 144M 144M 0 100% /snap/gnome-3-28-1804/23
/dev/loop10 54M 54M 0 100% /snap/core18/782
/dev/loop9 1.0M 1.0M 0 100% /snap/gnome-logs/57
/dev/loop8 13M 13M 0 100% /snap/gnome-characters/139
/dev/loop11 35M 35M 0 100% /snap/gtk-common-themes/818
/dev/loop12 4.2M 4.2M 0 100% /snap/gnome-calculator/352
/dev/loop13 15M 15M 0 100% /snap/gnome-logs/45
/dev/loop14 141M 141M 0 100% /snap/gnome-3-26-1604/78
/dev/loop15 35M 35M 0 100% /snap/gtk-common-themes/1122
/dev/loop16 3.8M 3.8M 0 100% /snap/gnome-system-monitor/70
/dev/loop17 15M 15M 0 100% /snap/gnome-characters/206
/dev/loop18 2.3M 2.3M 0 100% /snap/gnome-calculator/260
/dev/loop19 174M 174M 0 100% /snap/spotify/34
/dev/nvme0n1p1 256M 34M 223M 13% /boot/efi
tmpfs 1.6G 16K 1.6G 1% /run/user/121
tmpfs 1.6G 52K 1.6G 1% /run/user/1000
When I open Disk Usage Analyzer, I see the following:
Overview of disks in Disk Usage Analyzer
where the "106 GB Volume" used to be my "main" hard drive, where I had many of my programs, pictures etc, and by default it is unmounted. When I click it to mount it and run df -h again, it outputs the following:
tmpfs 7.7G 25M 7.7G 1% /dev/shm
tmpfs 1.6G 48K 1.6G 1% /run/user/1000
/dev/nvme0n1p7 97G 61M 92G 1% /media/william/633b2560-ee34-420d-84bb-138f68537887
where the 106gb drive is now added (I deleted everything on it, hence the usage %).
When restarting the computer, the drive is unmounted once again.
My question is: How can I make this drive my "main" drive once again, automatically mounted when the computer is booted and automatically the drive applications are installed onto, instead of the root, which (as far as I'm concerned) should only be used for system critical files and applications. This was not a problem before I reinstalled Ubuntu.
Please tell me if I need to provide any more info. Thanks in advance.
