You were using the wrong /dev/nvme0... name:
$ sudo tune2fs -l /dev/nvme0n1
tune2fs 1.42.13 (17-May-2015)
tune2fs: Bad magic number in super-block while trying to open /dev/nvme0n1
Couldn't find valid filesystem superblock.
The right format is:
$ sudo tune2fs -l /dev/nvme0n1p6
Filesystem volume name: New_Ubuntu_16.04
Last mounted on: /
Filesystem UUID: b40b3925-70ef-447f-923e-1b05467c00e7
Filesystem magic number: 0xEF53
Filesystem revision #: 1 (dynamic)
Filesystem features: has_journal ext_attr resize_inode dir_index filetype needs_recovery extent flex_bg sparse_super large_file huge_file uninit_bg dir_nlink extra_isize
Filesystem flags: signed_directory_hash
Default mount options: user_xattr acl
Filesystem state: clean
Errors behavior: Continue
Filesystem OS type: Linux
Inode count: 2953920
Block count: 11829504
Reserved block count: 534012
Free blocks: 6883701
Free inodes: 2277641
First block: 0
Block size: 4096
Fragment size: 4096
Reserved GDT blocks: 1021
Blocks per group: 32768
Fragments per group: 32768
Inodes per group: 8160
Inode blocks per group: 510
Flex block group size: 16
Filesystem created: Thu Aug 2 20:14:59 2018
Last mount time: Thu Apr 4 21:05:29 2019
Last write time: Thu Feb 14 21:36:27 2019
Mount count: 377
Maximum mount count: -1
Last checked: Thu Aug 2 20:14:59 2018
Check interval: 0 (<none>)
Lifetime writes: 4920 GB
Reserved blocks uid: 0 (user root)
Reserved blocks gid: 0 (group root)
First inode: 11
Inode size: 256
Required extra isize: 28
Desired extra isize: 28
Journal inode: 8
First orphan inode: 1308352
Default directory hash: half_md4
Directory Hash Seed: a179d56c-6c68-468c-8070-ffa5bb7cd973
Journal backup: inode blocks
As far as lifetime of NVMe SSD goes:
$ sudo nvme smart-log /dev/nvme0
Smart Log for NVME device:nvme0 namespace-id:ffffffff
critical_warning : 0
temperature : 38 C
available_spare : 100%
available_spare_threshold : 10%
percentage_used : 0%
data_units_read : 22,351,778
data_units_written : 14,667,833
host_read_commands : 379,349,109
host_write_commands : 127,359,479
controller_busy_time : 952
power_cycles : 1,925
power_on_hours : 1,016
unsafe_shutdowns : 113
media_errors : 0
num_err_log_entries : 598
Warning Temperature Time : 0
Critical Composite Temperature Time : 0
Temperature Sensor 1 : 38 C
Temperature Sensor 2 : 49 C
Temperature Sensor 3 : 0 C
Temperature Sensor 4 : 0 C
Temperature Sensor 5 : 0 C
Temperature Sensor 6 : 0 C
Temperature Sensor 7 : 0 C
Temperature Sensor 8 : 0 C
The key line here is:
After 18 months of use the SSD percentage use is 0%. If after 3 years of use it hits 1% then I know the SSD will last 300 years.
Obviously this answer would not fit into comment section to reply to other comments.
