I’m new to Linux/Ubuntu. To my knowledge it’s not possible to make file or folder with only difference in case e.g. I can’t create the files Text.ini and text.ini (well you can but it will not work, it gives you an error), so why does the terminal care about case when you write path to something e.g. cd folder/folder but if the second folder starts with capital F then command doesn’t work?
In Windows it doesn’t matter with capital letters or not it works, so is there any way for the terminal to ignore case if the names are correct?
