I am getting an error while trying to install sklearn:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
cuda-drivers : Depends: nvidia-418 (>= 418.40.04) but it is not going to be installed
libcuda1-418 : Depends: nvidia-418 (>= 418.40.04) but it is not going to be installed
nvidia-418-dev : Depends: nvidia-418 (>= 418.40.04) but it is not going to be installed
nvidia-opencl-icd-418 : Depends: nvidia-418 (>= 418.40.04) but it is not going to be installed
python-sklearn : Depends: python-numpy but it is not going to be installed
Depends: python-scipy but it is not going to be installed
Depends: python-sklearn-lib (>= 0.19.1-3) but it is not going to be installed
Depends: python-joblib (>= 0.9.2) but it is not going to be installed
Recommends: python-nose but it is not going to be installed
Recommends: python-pytest but it is not going to be installed
Recommends: python-matplotlib but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I tried sudo apt --fix-broken install but I get:
Unpacking nvidia-418 (418.40.04-0ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/nvidia-418_418.40.04-0ubuntu1_amd64.deb (--unpack):
trying to overwrite '/usr/lib/x86_64-linux-gnu/libGLX_indirect.so.0', which is also in package libglx-mesa0:amd64 18.2.2-0ubu ntu1~18.04.2
Also tried purging either nvidia-418 or the packages dependent on it using sudo apt-get remove --purge getdeb-repository to no avail. How do I deal with this?
