I have a Chromebook that I would like to install Ubuntu on. I previously had GalliumOS on it, but for several reasons, I choose not to use it. I then installed full Ubuntu on the laptop, leaving only a little more than a gb of free space left on the device.
I finally decided to install Ubuntu Minimal on the Chromebook. I have had experience with Ubuntu Minimal in the past, but never setting it up. However, my Chromebook does not have an Ethernet port on it. I could not download any utilities to connect to WiFi without WiFi.
My question is: is it possible to setup Ubuntu Minimal only using WiFi. If I can not, is there any good very lightweight replacement distributions you recommend? I have previously looked up this answer and got this result
I am not aware of any method to connect to a WPA network only with terminal commands.
While this seems pretty cut and dried, that post was from 2010. Things may have changed.
I have found several similar questions here, but most of them include installing another program. Which requires internet. Thanks for any feedback.
I have tried many distribution on my laptop and I run into the same problem. I really dont like gnome but ubuntu-server doesnt work with wifi install. So I use a regular ubuntu desktop version. dd it to a usb and boot from it. Open a terminal and start type the following. Make sure you change your device. (as yours may not sda)
# create gpt table
sudo fdisk /dev/sda
sudo mkfs.fat -F32 /dev/sda1
sudo mkfs.ext4 /dev/sda2
sudo mkfs.ext4 /dev/sda3
cd /tmp && wget http://archive.ubuntu.com/ubuntu/pool/main/d/debootstrap/debootstrap_1.0.114ubuntu1_all.deb
cd /tmp && dpkg -i debootstrap*.deb
sudo mkdir -p /mnt/usb
sudo mount /dev/sda2 /mnt/usb
sudo mkdir /mnt/usb/boot
sudo mount /dev/sda1 /mnt/usb/boot
sudo debootstrap bionic /mnt/usb http://hk.archive.ubuntu.com/ubuntu/
sudo mount -o bind /dev /mnt/usb/dev
sudo mount -o bind /dev/pts /mnt/usb/dev/pts
sudo mount -t sysfs /sys /mnt/usb/sys
sudo mount -t proc /proc /mnt/usb/proc
sudo cp /etc/apt/sources.list /mnt/usb/etc/apt/
sudo chroot /mnt/usb apt-get update
sudo chroot /mnt/usb apt-get -y install grub-efi-amd64 sudo make git ssh linux-firmware linux-image-generic nano intel-microcode curl software-properties-common unzip network-manager net-tools wpasupplicant
# add your packages here, Install your driver here
# sudo chroot /mnt/usb apt-get -y install papirus-icon-theme cpanminus gexec libcpan-distnameinfo-perl libcpan-meta-check-perl libfile-pushd-perl liblocal-lib-p$
# sudo chroot /mnt/usb apt-get -y install xorg openbox obconf lxterminal conky tint2 feh pcmanfm xarchiver chromium-browser gmrun
# sudo chroot /mnt/usb apt-get -y install viewnior ttf-wqy-microhei
# sudo chroot /mnt/usb apt-get -y install transmission-gtk rar unrar zip evince scrot
# sudo chroot /mnt/usb apt-get -y install alsa-utils pulseaudio bluez
sudo chroot /mnt/usb passwd
sudo echo -e "/dev/sda1  /boot       vfat    umask=0077      0       1" | sudo tee -a /mnt/usb/etc/fstab
sudo echo -e "/dev/sda2 /               ext4    errors=remount-ro 0       1"  | sudo tee -a /mnt/usb/etc/fstab
sudo echo -e "/dev/sda3 /home               ext4    defaults        0       2"  | sudo tee -a /mnt/usb/etc/fstab
# Following in chroot environment
apt-get install grub-efi-amd64
grub-mkdevicemap
grub-mkconfig -o /boot/grub/grub.cfg
update-grub
grub-install --target=x86_64-efi  --bootloader-id=grub_uefi --efi-directory=/boot
sudo shutdown -r now
After reboot get online with
nmtui
Hairy Ass
  • 121
