I have a script, which starts the execution of multiple C++-programs. I have to execute those with sudo, as they use some "restricted" linux libs/files(probably not the right nomenclature, but you get what i mean). Now i would like to write a shell-script which calls those binaries one after the other, but i do not know how to do this:
#!/bin/bash
./main a > out/output2DFloat.csv
./main a a > out/output3DFloat.csv
./main a a a > out/output2DDouble.csv
./main a a a a > out/output3DDouble.csv
and call this with sudo? Or append Sudo before each and call it with sudo...
My fear is, that the sudo timer runs out, before even one is finished, which would lead to big problems, if the next ones then need sudo-rights ...
Clebo Sevic
  • 119
You could just write sudo in front of every command, which needs sudo rights. If "the sudo timer runs out", you will be prompted again. This would look like
#!/bin/bash
sudo ./main a > out/output2DFloat.csv
sudo ./main a a > out/output3DFloat.csv
sudo ./main a a a > out/output2DDouble.csv
sudo ./main a a a a > out/output3DDouble.csv
then.
To not enter sudo password twice or more, you can use subshell and heredoc, like this:
#!/bin/bash
sudo /bin/bash <<EOF
EOF
LeonidMew
  • 2,802
You can use suid to run your program with root privileges (no need to enter password each time):
Normally, when a program runs under Linux, it inherits the permissions of the user who is running it, thus if I run a program under my account, the program runs with the same permissions that I would have if that program were me. Thus, if I cannot open a certain file, the program I am running also cannot open the file in question.
If I set the SUID or SGID bit for a file, this causes any persons or processes that run the file to have access to system resources as though they are the owner of the file read more...
So you can easily change the ownership of script file:
chown root:user <script file>
Put your username instead of user. Then change the permission of the script file like this:
chmod g+s <script file>
